1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Arrays in Start Up Scripts
To: Darrell Nineham <[email protected]>
Cc: [email protected]
Date: Wed, 10 Aug 2005 11:48:12 +0200
Darrell Nineham wrote:
Dear Fellow Tech-Talkers,
I'd like to pass an array of bytes into a config call in an EPICS start up script.
Anyone know of a trick for declaring and initialising an array in an EPICS / VxWorks start up script ?
Darrell Nineham
Darell,
Have a look at the autoSaveRestore package from APS. It doesn't work in the way you describe though, but should be able to do what you want.
You specify "autoRestore" files in your startup script containing lists of PV names and values. These files are then read during iocInit and the corresponding values set. It can handle arrays. The files are normally created by the autoSave mechanism but, for special cases such as yours, can also be created manually.
The package is used quite widely here at SLS.
Regards, David
                               [email protected]
     _/_/_/   _/   _/_/_/     Beamline Control Group, SLS Project
    _/       _/   _/         Paul Scherrer Institute
     _/_/   _/     _/_/     CH-5232 Villigen-PSI
        _/ _/         _/   Tel: +41 56 310 3616
   _/_/_/ _/_/_/ _/_/_/   Fax: +41 56 310 3294
Arrays in Start Up Scripts Darrell Nineham
Prev: Arrays in Start Up Scripts Darrell Nineham
Next: RE: Arrays in Start Up Scripts Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Arrays in Start Up Scripts Ernest L. Williams Jr.
