1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: epics ca_put logging on Windows
To: [email protected]
Date: Thu, 11 Aug 2005 09:34:18 -0500
I am trying to use Ca Put Logging facility on Windows IOC (epics base 3.14.7) but don't see anything in output log file.
My ASF is the following:
UAG(CTLGRP) {d0ctl,sirotenk}
HAG(CTLGRP) {d0ol75.fnal.gov,d0ollpt07.fnal.gov}
ASG(DEFAULT)
   RULE(1,READ)
   RULE(1,WRITE,TRAPWRITE)
 UAG(CTLGRP)
 HAG(CTLGRP)
At IOC side I set the following:
set EPICS_IOC_CA_PUT_LOG_INET=131.225.227.47
set EPICS_IOC_LOG_INET=131.225.227.47
set EPICS_IOC_CA_PUT_LOG_PORT=7010
set EPICS_IOC_LOG_PORT=6500
and run two iocLogServers as recommended with the following sets:
set EPICS_IOC_LOG_FILE_NAME=./log_server.txt
set EPICS_IOC_LOG_FILE_LIMIT=1000000
and
set EPICS_IOC_LOG_FILE_NAME=./log_server_ca_put.txt
set EPICS_IOC_LOG_PORT=7010
I see some init messages in log_server.txt file, so logging itself works. But file log_server_ca_put.txt remains empty after I made several
CA puts to the IOC. When I listen port 7010 directly, there are no packets arriving to that port
What I am doing wrong?
Vladimir
Prev: Re: msi command for building synApps 5.1 J. Lewis Muir
Next: Subversion Debora Kerstiens
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Keithley6517A Electromete GPIB Device Support Ralph Lange
