1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Gateway and EPICS_CA_MAX_ARRAY_BYTES
To: "Tech-Talk" <[email protected]>
Date: Mon, 22 Aug 2005 09:29:53 -0500
There is a problem in Channel Access with EPICS_CA_MAX_ARRAY_BYTES that
causes problems in the Gateway.  It has to do with one of the sockets not
being set to non-blocking (so it ends up blocking the Gateway).  It is
Mantis bug #176.  It will be fixed in 3.14.8 but you can contact Jeff for a
patch.
In regard to our experience: We set EPICS_CA_MAX_ARRAY_BYTES to 14000O on a
site-wide basis here and have not noticed problems.  Of course, you can
always overload the Gateway by sending enough traffic.  There are many ways
to monitor the Gateway and look for users that start processes with abnormal
loads.  See the EPICS page at
http://www.aps.anl.gov/epics/extensions/gateway/index.php.  (There is also a
paper there on the APS experience with the Gateway and what kind of loads we
handle.)  We have had to, for example, encourage users to not monitor
hundreds of BPMs at KHz rates when going through the Gateway (or at least to
not have several people doing that at the same time ;-).
	-Ken
Prev: Re: Gateway and EPICS_CA_MAX_ARRAY_BYTES Dirk Zimoch
Next: CA loss package on 1 Hz rate Liyu, Andrei
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Table tool in EDM Chithra Karunakaran
