1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CA loss package on 1 Hz rate
To: "Liyu, Andrei" <[email protected]>, [email protected]
Date: Tue, 23 Aug 2005 10:07:48 +0900
Hello
In my EPICS system, I got similor situation.
Data is only one Ai (or CALC) record. And there is two PC linux EPICS IOCs.
Data is generate on first EPICS IOS and access from second EPICS IOC (AI record) to read it (CAget).
Both EPICS IOC works each SCAN period 40msec (25Hz).
Channel Archiver is working on the second PC and archiveing both first and second IOCs data.
Archived data from first IOC is almost perfect, but data from second IOC have some data loss or like that.
I think this data loss due to same reason of Andrei's trouble.
It means, due to the difference of clock frequency of PC (not CPU frequency).
For example, first PC may be work at 1.0001 second par 1 second.
And second PC may work at 1.0002 second par 1 second.
In this case, after 400 second, CA cycle of second PC outrun the first PCs, and double the archived data.
I think this is the source of the problem.
caution: SCAN period on my EPICS IOCs are set at 0.039 second and works at "almost" 40 msec with 1000Hz tick frequency.
Motoki Ooi
Liyu, Andrei wrote:
	SNS BLM system has 2 levels. First level is VME based/vxWorks
(IOC). Second level is PC/Windows (PC) - similar CAGateway. IOC sends
data one time per second to PC. Data is arrays (one array (720 floats)
per detector; up to 32 detectors per IOC). Array has information about
serial number of current package. PC checks serial number and prints on
terminal port if data was lost or come twice. Time to time (very seldom)
I read both problems.
	SNS works on 1 Hz now. IOC CPU loading ~ 3-5% and PC CPU loading
5%. On 60 Hz IOC will have 30% on 60 Hz. PC doesn't depend of
accelerator rate but depends from clients quantity.
	I hoped to use CAArchive to find source of problem. But I met
another problem. Archive lost connection to IOC when IOC/PC connection
was Ok.
	Does anyone see this problem? Any other suggestions to find the
source (IOC, network, PC)?
Thanks, Andrei.
CA loss package on 1 Hz rate Liyu, Andrei
Prev: RE: CA loss package on 1 Hz rate Jeff Hill
Next: RE: CA loss package on 1 Hz rate Liyu, Andrei
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
