1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: SNCSEQ...
To: "Andrew Johnson" <[email protected]>
Cc: "EPICS tech-talk" <[email protected]>
Date: Fri, 2 Sep 2005 11:47:16 -0700
Hi Andrew- Ernest helped me figure out that it was a mismatch between the SNCSEQ def in
configure/RELEASES in the app & local seq trees.  The "<SLACstuff>" & xyz/ are just so I
wouldn't bore you with our local /afs paths; sorry about the confusion!
And there really is a gap in the "but SNCSEQ at  has", but as that msg goes away when
I fix the RELEASEs, I don't know why that happened...
thanks for your help,
Mike
-----Original Message-----
Sent: Friday, September 02, 2005 7:45 AM
To: Laznovsky, Michael
Cc: EPICS tech-talk
Subject: Re: SNCSEQ...
Laznovsky, Michael wrote:
> 	gmake[1]: Entering directory `/u/cd/xyz/tmp-xyz/ioc/configure'
> 	perl <SLACstuff>/epics/R3.14.6/base/configure/tools/convertRelease.pl -h solaris-sparc checkRelease
> 	Definition of SNCSEQ conflicts with SNCSEQ support.
> 	In this application configure/RELEASE defines
> 	        SNCSEQ = /u/cd/xyz/work/seq-2.0.10
> 	but SNCSEQ at  has
> 	        SNCSEQ = <SLACstuff>/epics/R3.14.6/site
> 	gmake[1]: *** [checkRelease] Error 1
> I don't see where the second definition in the error comes from.  It's not
> anywhere in the installed EPICS area that I can find.
Is the text above *exactly* as reported by the tool, or did you edit the
two "<SLACstuff>" parts?  I note that the second line above has
<SLACstuff> in the path to the convertRelease.pl script, and that looks
to be part of the problem.  Check whether SNCSEQ (or SLACstuff even) is
found anywhere in your <base>/configure directory.  Do you use an
automounter that uses soft links and gives different paths to mounted
file systems?
There should be a path printed in between the words "but SNCSEQ at" and
"has"; if that path really is empty it could be reading a file from the
root path /configure/RELEASE so have a look there too.  Finally, I'm not
sure what will happen if the SNCSEQ installation itself has a definition
for SNCSEQ in its own configure/RELEASE file, so make sure there isn't
one set there.
Let us know what you find...
- Andrew
English arose from Normans trying to pick up Saxon girls.
Prev: Keithley 237 Luchini, Kristi
Next: Call for Volunteers: 3.13 Record Reference Manual Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: SNCSEQ... Emmanuel Mayssat
Next: archive viewer installation problem Christophe Moins
