1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: TRAPWRITE and logging CA_PUT activity
To: Ralph Lange <[email protected]>
Cc: [email protected]
Date: Fri, 16 Sep 2005 14:17:31 -0500
Thanks, Ralph
But where I can get the module CA Put Logging itself? In CA Put Logging doc page (link from Epics Extensions web page) is written that for epics 3.13.4 and higher : "All the necessary routines and libraries to provide Trap Write Hook are placed into base. Modules dealing with CA Put Logging are placed in the directory EpicsBase/src/caPutLog" ... Trap Write Hook is there, in base release. Where to find caPutLog? I tried to access DESY ftp server (link from CA Put Logging doc page) with hope that I could find it there but link failed.
Can you help please?
Vladimir
----- Original Message -----
Sent: Friday, September 16, 2005 12:40 PM
Hi Vladimir,
It's exactly as you were citing from the Release Notes:
EPICS Base itself does not provide this ability, but only the hook needed by such a facility.
This new hook facility is described in more detail in the 3.14 Application Developer's Guide, in chapter 8.8 ("Trapping Channel Access Writes").
Documentation on the DESY "CA Put Logging" module, which can be hooked into this facility, can be found on the DESY page that can be reached from the "Extensions" page of the EPICS Web (section "Other Tools or Libraries").
There are no plans to include such plug-in modules into EPICS Base.
Hope this helps,
Ralph
Vladimir Sirotenko wrote:
Can anyone answer the following question: is mechanism to log ca write activity implemented in 3.14 base epics release? According to documentation, it is supposed to
( http://www.aps.anl.gov/asd/controls/epics/EpicsDocumentation/ReleaseNotes/ReleaseNotes3.13.4.html : "The purpose of this new facility is to allow things like logging Channel Access writes. Epics base itself does not provide this ability but only the hook needed by such a facility. DESY has developed a facility that logs CA puts. The trap writes feacure allows the DESY facility to be implemented without any changes to epics base. In addition it allows the user to decide what should be logged. This new facility will be described in more detail in the 3.14 version of the Application Developer's Guide."
but if I just look for the presence of environmental name EPICS_IOC_CA_PUT_LOG_INET or as was suggested by V.Korobov name which is supposed to be used in later CA_PUT release: EPICS_IOC_LOG_CONFIG_FILE_NAME, then both are missing in src directory of the epics base 3.14.6
Does anyone use such tools? And how?
Vladimir
Re: TRAPWRITE and logging CA_PUT activity Ralph Lange
TRAPWRITE and logging CA_PUT activity Vladimir Sirotenko
Prev: Re: TRAPWRITE and logging CA_PUT activity Ralph Lange
Next: Re: TRAPWRITE and logging CA_PUT activity Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
