Correction
> I must admit that I don't routinely test the native port of EPICS
> on windows,
> but not the cygwin port which is in essence POSIX running on top of win32.
> This is mostly because there are always too many things to get done.
I must admit that I routinely test the native port of EPICS on windows,
> -----Original Message-----
> From: Jeff Hill [mailto:[email protected]]
> Sent: Thursday, September 29, 2005 6:55 PM
> To: 'Mark Rivers'; [email protected]
> Subject: RE: Channel access problem on cygwin IOC
> Mark,
> > CAC: Unable to connect because "Connection refused"
> This might occur when the IP kernel thinks that it does not have a server
> on
> the CA port, or that too many circuits connect at once and backlog exceeds
> the listen count.
> Another possibly is that an IOC was connected before and was restarted.
> When
> that happens there are some subtleties related to SO_REUSEADDR which
> basically override the IP kernel's preference to not allow a service to
> reuse a TCP port until a long timeout has expired (and all packets
> traveling
> around the internet heading for that port have either arrived at the
> server's host or exceeded TTL). People seem to abhor the default behavior
> and so we have had SO_REUSEPORT enabled for a long time, but perhaps this
> isn't working correctly with cygwin.
> I notice this code in the native win32 port.
> * Note: WINSOCK appears to assign a different functionality for
> * SO_REUSEADDR compared to other OS. With WINSOCK SO_REUSEADDR indicates
> * that simultaneously servers can bind to the same TCP port on the same
> host!
> * Also, servers are always enabled to reuse a port immediately after
> * they exit ( even if SO_REUSEADDR isnt set ).
> epicsShareFunc void epicsShareAPI
> epicsSocketEnableAddressReuseDuringTimeWaitState ( SOCKET s )
> Personally, I don't have any experience with the cygwin port of EPICS. I
> must admit that I don't routinely test the native port of EPICS on
windows,
> In the past when I did try that version there were some mysterious
> behaviors
> related to sockets w/o any clear workarounds, but that was quite some time
> back when cygwin first started out, and cygwin is definitely improving all
> the time.
> However, when a person wants to use cygwin on windows I suspect that what
> they want is the cygwin environment, and not necessarily the cygwin port
> of
> EPICS which involves additional overhead routing the EPICS OSI layer first
> to cygwin posix and then on to win32 and winsock, and no way to
> concentrate
> our attention on the specific OS features that EPICS needs. With the
> native
> port the EPICS OSI layer goes directly to win32 and winsock. The native
> port
> (implementation of the EPICS OSI layer) is carefully optimized and tested
> for windows.
> I don't have anything against cygwin. It's really a great idea avoiding
> the
> draconian limits built into MS's "POSIX subsystem" - which no one seems to
> really use. However I like being able to optimize the OSI layer for win32,
> and I'm not ecstatic about having to chase bugs in two ports.
> One way to avoid having to test and maintain two versions would be to not
> use cygwin-x86 (which was I think formerly incorrectly called
> win32-x86-cygwin) and instead use win32-x86-cygwin (which consistent with
> other OS should mean build EPICS for win32-x86 with the cygwin compiler).
> Unfortunately, the config files for win32-x86-cygwin do not yet exist, but
> I
> suspect that the effort required to create them might be less than the
> long
> term effort required to maintain two ports of EPICS on windows. One
> possible
> peril with this idea might be mix ups occurring when win32 posix-like
> header
> files get confused with cygwin posix header files (this is probably a
> non-issue with sockets). There could also be problems with library search
> paths. When setting up the config files these are issues to be cognizant
> of.
> The cygwin GNU C/C++ RTL is probably going to work fine with the native
> port.
> There's my two cents worth.
> Jeff
> > From: Mark Rivers [mailto:[email protected]]
> > Sent: Thursday, September 29, 2005 12:53 PM
> > To: [email protected]
> > Subject: Channel access problem on cygwin IOC
> > I am having an intermittent problem with channel access on a cygwin IOC.
> > Sometimes when the IOC starts everything works fine, but sometimes I get
> > the following behavior:
> > - No channel access clients are able to connect to any PVs on the IOC.
> I
> > get the following types of errors:
> > corvette> caget dxpXMAP:med:mca1.ERTM
> > CA.Client.Exception...............................................
> > Warning: "Virtual circuit disconnect"
> > Context: "164.54.160.5:5064"
> > Source File: ../cac.cpp line 1145
> > Current Time: Thu Sep 29 2005 13:49:55.763202000
> > Channel connect timed out: 'dxpXMAP:med:mca1.ERTM' not found.
> > - casr on the IOC produces the following, which seems OK to me.
> > epics> casr 50
> > Channel Access Server V4.11
> > No clients connected.
> > UDP Server:
> > UDP 164.54.160.111:50650(): User="", V4.11, 0 Channels, Priority=0
> > Task Id=0x103987b0, Socket FD=8
> > Secs since last send 34.40, Secs since last receive 0.12
> > Unprocessed request bytes=16, Undelivered response bytes=0
> > State=up
> > 168 bytes allocated
> > Send Lock
> > epicsMutexId 0x10399060 source ../caservertask.c line 673
> > ownerTid 0x0 count 0 owned 0
> > Put Notify Lock
> > epicsMutexId 0x10399158 source ../caservertask.c line 674
> > Address Queue Lock
> > epicsMutexId 0x10399250 source ../caservertask.c line 675
> > Event Queue Lock
> > epicsMutexId 0x10399348 source ../caservertask.c line 676
> > Block Semaphore
> > There are currently 1176 bytes on the server's free list
> > 7 client(s), 0 channel(s), 0 event(s) (monitors) 0 putNotify(s)
> > 0 small buffers (16384 bytes ea), and 0 jumbo buffers (16408 bytes ea)
> > The server's resource id conversion table:
> > Bucket entries in use = 0 bytes in use = 16404
> > Bucket entries/hash id - mean = 0.000000 std dev = 0.000000 max = 0
> > The server's array size limit is 16408 bytes max
> > Channel Access Address List
> > 164.54.160.255:5065
> > Any ideas on what the problem could be, or how to track it down? This
> is
> > a new problem, I have been running cygwin IOCs for many months with no
> > problem. I am developing a new application that has started to produce
> > these symptoms.
> > Thanks,
> > Mark
- RE: Channel access problem on cygwin IOC Jeff Hill
RE: Channel access problem on cygwin IOC Ernest L. Williams Jr.
<2005>
2025
2026
<2005>
2025
2026
