1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: 64-bit EPICS anyone?
To: "Ernest L. Williams Jr." <[email protected]>
Cc: [email protected]
Date: Tue, 18 Oct 2005 16:39:14 -0400
I built and used EPICS base and many of the extensions on Alphas
(DECUnix/Tru64).  There were a few issues with older extensions that were
coded assuming pointer=int=long, mostly easily fixed.
Properly written X/Motif applications should not be a problem, as X and
Motif were designed to be architecture/word-size independent.
I even tried to build XView (for the old archiver) from source, without
success.  Some poking around on the net turned up an Alpha port which
worked.
I was using the native DEC compilers.  GCC generally worked also, but the
DEC compiler was faster and tended to generate more compact code.  I never
tested whether it ran faster or not.
Brian McAllister                                   Senior Software Engineer
[email protected]                             MIT-Bates Linear Accelerator
(617) 253-9537                                                Middleton, MA
archiver, Re: 64-bit EPICS anyone? Kay-Uwe Kasemir
Re: 64-bit EPICS anyone? Ernest L. Williams Jr.
Prev: t202/SNS-patched 68K compiler bug Ronald L. Sluiter
Next: archiver, Re: 64-bit EPICS anyone? Kay-Uwe Kasemir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: 64-bit EPICS anyone? Ernest L. Williams Jr.
