Craig,
I was having a similar problem with RHEL4 a couple of months ago. It
seems that MEDM needs to have the following in the X font server path
for RHEL4 /usr/X11R6/lib/X11/fonts/75dpi.
If you run the command /usr/sbin/chkfontpath you will see a listing of
directories in the font path. By default RHEL4 includes
/usr/X11R6/lib/X11/fonts/75dpi:unscaled which will prevent you from
adding the other font directory to the path. The only way I found around
this was to remove the 75dpi font directories from the path and then add
it back:
chkfontpath -r /usr/X11R6/lib/X11/fonts/75dpi
chkfontpath -a /usr/X11R6/lib/X11/fonts/75dpi
This will add both /usr/X11R6/lib/X11/fonts/75dpi and
/usr/X11R6/lib/X11/fonts/75dpi:unscaled to you font path.
Conrad G. Zadlo, Jr.
Computer Network Assistant
Intense Pulsed Neutron Source (IPNS)
9700 S. Cass Av. Bldg 360
Argonne, IL 60439
[email protected]
Phone: 630-252-3207
Fax: 630-252-9987
-----Original Message-----
Sent: Tuesday, October 18, 2005 4:08 PM
To: TECHTALK
Subject: White Box 4 and medm scalable fonts
Hi Folks:
Has anyone had problems with medm scalable fonts with White Box
Enerprise Linux 4 (WBEL4). We just installed this on our machines and
cannot get the medm scalable fonts to work. They did work with WBEL3.
Craig
Craig Walther Email: [email protected]
Joint Astronomy Centre Phone: (808) 969-6556
660 N. A'ohoku Place Fax: (808) 961-6516
Hilo, Hawaii 96720 USA
EPICS/Labview shared memory implementation and Labview 8 Chestnut, Ronald P.
More on fonts and RHEL4 Chestnut, Ronald P.
<2005>
2025
2026
White Box 4 and medm scalable fonts Craig Walther
<2005>
2025
2026
