1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: FMB LoCuM-4 current monitor
To: "Gillingham, IJ \(Ian\)" <[email protected]>
Cc: [email protected]
Date: Thu, 20 Oct 2005 10:33:20 +0200
Gillingham, IJ (Ian) wrote:
Hello,
Is anyone aware of any EPICS support for the FMB LoCuM-4 low current
monitor.  We intend to use them with PBPMs.  Thought I would ask before
re-inventing the proverbial wheel.
Ian
Ian Gillingham
Senior Electronic Systems Engineer
Diamond Light Source Ltd.
Rutherford Appleton Laboratory
Chilton
Didcot
Oxfordshire OX11 0QX
Tel: +44 (0)1235 778129
Fax: +44 (0)1235 778468
Email: [email protected]
We are using LoCuM-4 for PBPMs at the SLS. Of course, I can provide you the EPICS templates. The 0-10V output of the LoCuM-4 we digitize with 16-bit Hytec8401 ADCs sitting in Hytec8002 carrier boards.
Actually, there are 3 templates used for photon monitors (PBPMs):
* 1st is used to read/convert the signals according to the auto-range LoCuM signal.
* 2nd is used to calculate the PBPM asymmetries and positions, actually there are 2 types used depending on the PBPM type
* 3rd is used for studying the dynamics of the photon beam in frequency domain by means the buffering capabilities of the Hytec8401 ADC.
Juraj
FMB LoCuM-4 current monitor Gillingham, IJ (Ian)
Prev: FMB LoCuM-4 current monitor Gillingham, IJ (Ian)
Next: RE: EPICS/Labview shared memory implementation and Labview 8 Purcell, J. David
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: asyn Chithra Karunakaran
