1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: asyn
To: Chithra Karunakaran <[email protected]>
Date: Thu, 20 Oct 2005 10:41:24 -0500
You are missing the envPaths file in your application startup directory.
Edit the Makefile in that directory and that the following line is present:
TARGETS = envPaths
On Oct 20, 2005, at 9:35 AM, Chithra Karunakaran wrote:
Hi:
I am compiling the example device support and application given in “How to create EPICS device support for a simple serial or GPIB device” guide. I find the guide very useful. The device support part compiles without any problem. When I compile the application and run the IOC application I get the following error.
Any one has a suggestion.  I have copied the directory structure and the error messages. I am compiling the programs on a linux machine using EPICS3.14.7
AB302App  AB302Sup  bin  configure  db  dbd  documentation  iocBoot  lib  Makefile
#!../../bin/linux-x86/AB302
## You may have to change AB302 to something else
## everywhere it appears in this file
< envPaths
Can't open envPaths: No such file or directory
macLib: macro TOP is undefined (expanding string cd ${TOP})
dbLoadDatabase("dbd/AB302.dbd",0,0)
filename="../dbLexRoutines.c" line number=234
No such file or directory dbRead opening file dbd/AB302.dbdAB302_registerRecordDeviceDriver(pdbbase)
registerRecordDeviceDriver failed ai
registerRecordDeviceDriver failed ao
registerRecordDeviceDriver failed bi
registerRecordDeviceDriver failed bo
registerRecordDeviceDriver failed calc
registerRecordDeviceDriver failed calcout
registerRecordDeviceDriver failed compress
registerRecordDeviceDriver failed dfanout
registerRecordDeviceDriver failed event
registerRecordDeviceDriver failed fanout
registerRecordDeviceDriver failed longin
registerRecordDeviceDriver failed longout
registerRecordDeviceDriver failed mbbi
registerRecordDeviceDriver failed mbbiDirect
registerRecordDeviceDriver failed mbbo
registerRecordDeviceDriver failed mbboDirect
registerRecordDeviceDriver failed permissive
registerRecordDeviceDriver failed sel
registerRecordDeviceDriver failed seq
registerRecordDeviceDriver failed state
registerRecordDeviceDriver failed stringin
registerRecordDeviceDriver failed stringout
registerRecordDeviceDriver failed sub
registerRecordDeviceDriver failed subArray
registerRecordDeviceDriver failed waveform
registerRecordDeviceDriver failed asyn
macLib: macro AB302 is undefined (expanding string cd ${AB302})
dbLoadRecords("db/devAB302.db","P=AB302:,R=,L=0,A=0")
No such file or directory dbRead opening file db/devAB302.db## Load record instances
#dbLoadRecords("db/xxx.db","user=karunacHost")
macLib: macro TOP is undefined (expanding string cd ${TOP}/iocBoot/${IOC})
macLib: macro IOC is undefined (expanding string cd ${TOP}/iocBoot/${IOC})
drvAsynSerialPortConfigure("L0","/dev/ttyS0",0,0,0)
asynSetOption("L0", -1, "baud", "9600")
2005/10/19 16:15:38.409 /dev/ttyS0 Can't open  Permission denied
 166967288 autoConnect could not connect
bash-3.00$ ls
Makefile  st.cmd
Chithra.
Chithra Karunakaran
Canadian Light Source Inc.
Phone: (306) 657-3749
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
asyn Chithra Karunakaran
Prev: RE: asyn Mark Rivers
Next: RE: autosave V4.1 and caRepeater Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: asyn Chithra Karunakaran
Next: RE: asyn Mark Rivers
