1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: caSnoop build problem
To: <[email protected]>
Date: Wed, 2 Nov 2005 10:13:01 -1000
I’m trying to build caSnooper v2.1.0.1 using gcc version 3.3 on Solaris 8 with EPICS R3.13.10 (which built okay) but am getting the following compile error:
/usr/local/gcc/gcc-3.3-gnu/bin/g++ -ansi -pedantic -Wtraditional   -DSOLARIS=8  -g  -Wall -Wmissing-prototypes -Woverloaded-virtual -Wwrite-strings -Wconversion -Wstrict-prototypes -Wpointer-arith -Winline   -DcaNetAddrSock -DCAS_DIAGNOSTICS  -fPIC -D_REENTRANT  -DUNIX -DEXPL_TEMPL -I. -I..  -I/home/ktsubota/epics/r3.13.10/base/src/cas/generic -I/home/ktsubota/epics/r3.13.10/base/src/cas/generic/st -I/home/ktsubota/epics/r3.13.10/base/src/cas/io/bsdSocket -I../../../include -I../../../include/os/solaris -I/home/ktsubota/epics/r3.13.10/base/include/os/solaris -I/home/ktsubota/epics/r3.13.10/base/include   -c   ../snoopServer.cc
cc1plus: warning: "-Wtraditional" is valid for C/ObjC but not for C++
../snoopServer.cc: In member function `virtual pvExistReturn
   snoopServer::pvExistTest(const casCtx&, const char*)':
../snoopServer.cc:129: error: could not convert `
   *(pClient->casCoreClient::_vptr.ioBlocked + 76)()' to `caNetAddr&'
Using gcc version 2.95, I was able to build caSnooper.  Here is the same complile output with gcc v2.95:
/usr/local/bin/g++ -ansi -pedantic -Wtraditional   -DSOLARIS=8  -g  -Wall -Wmissing-prototypes -Woverloaded-virtual -Wwrite-strings -Wconversion -Wstrict-prototypes -Wpointer-arith -Winline   -DcaNetAddrSock -DCAS_DIAGNOSTICS  -fPIC -D_REENTRANT  -DUNIX -DEXPL_TEMPL -I. -I..  -I/home/ktsubota/epics/r3.13.10/base/src/cas/generic -I/home/ktsubota/epics/r3.13.10/base/src/cas/generic/st -I/home/ktsubota/epics/r3.13.10/base/src/cas/io/bsdSocket -I../../../include -I../../../include/os/solaris -I/home/ktsubota/epics/r3.13.10/base/include/os/solaris -I/home/ktsubota/epics/r3.13.10/base/include   -c   ../snoopServer.cc
../snoopServer.cc: In method `class pvExistReturn snoopServer::pvExistTest(const casCtx &, const char *)':
../snoopServer.cc:129: warning: initialization of non-const reference type `class caNetAddr &'
../snoopServer.cc:129: warning: from rvalue of type `caNetAddr'
Here ‘s more information on the two compilers:
laupahoehoe:O.solaris> /usr/local/bin/g++ -v
Reading specs from /usr/local/lib/gcc-lib/sparc-sun-solaris2.7/2.95.2/specs
gcc version 2.95.2 19991024 (release)
laupahoehoe:O.solaris> /usr/local/gcc/gcc-3.3-gnu/bin/g++ -v
Reading specs from /usr/local/gcc/gcc-3.3-gnu/lib/gcc-lib/sparc-sun-solaris2.8/3.3/specs
Configured with: ./configure --prefix=/usr/local/gcc/gcc-3.3-gnu --with-ld=/usr/local/binutils/binutils-2.13.1-gnu/bin/ld --with-as=/usr/local/binutils/binutils-2.13.1-gnu/bin/as --enable-shared --enable-threads -enable-languages=c++,f77
Thread model: posix
gcc version 3.3
Any help would be appreciated.
Mahalo!
Kevin
Prev: Re: More on fonts and RHEL4 Thomas Birke
Next: RE: caSnoop build problem Kenneth Evans, Jr.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: SDDS build error Kevin Tsubota
