1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Base 3.14.7 build error on SUSE machine
To: [email protected]
Date: Fri, 04 Nov 2005 12:27:41 +0100
We are currently resolving final issues and testing the next release of Base.
If your project allows for it, the smartest laid-back approach would be waiting for 3.14.8, which should be released within the next days (you can check the core-talk archive for latest information on the progress). Probably your problems will not appear using that version.
If you want to help or if you're in a hurry, start with the nightly CVS snapshot, which should already be pretty close to the final 3.14.8 release. If in that case your problems persists, it would be really nice to include a fix into 3.14.8 before it is published.
Thanks for your help!
Ralph
[email protected] wrote:
I've been trying to build the EPICS 3.14.7 Base on a i586-suse-linux system
using gcc 4.0.2, GNU Make 3.80, and Perl 5.8.7. After after many hurdles I've
finally hit a brick wall.
Base 3.14.7 build error on SUSE machine alcocer
Prev: Base 3.14.7 build error on SUSE machine alcocer
Next: MCF8252 processor UART1 and UART2 for RTEMS? Kiman Ha
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Base 3.14.7 build error on SUSE machine Andrew Johnson
