1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Channel Archiver/ Extension Build Question
To: [email protected]
Date: Wed, 09 Nov 2005 20:03:32 -0500
Dear All,
I am trying to build Channel Archiver with EPICS R3.14.7 on linux-x86.
I start from a blank slate by installing/building base into the directory base-3.14.7
I then download extensionsConfigure_20040406.tar.gz and unzip it so I now have the following tree
base-3.14.7/
   Makefile
   bin/
extensions/
   Makefile
   configure/
I edit extensions/configure/RELEASE so that the value of EPICS_BASE is correct.
I create the directory extensions/src into which I unzip archiver.tgz (a 11/07/2005 snapshot of the Channel Archiver) so that now I have
extensions/
   Makefile
   configure/
   src/
      ChannelArchiver
         Makefile
         /Tools
I change directory to extensions/src/ChannelArchiver and type "make".
Make creates the directory Tools/O.linux-x86, and then begins compiling the source in the Tools directory. When it gets to FUX.cpp I get the output:
/usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -ansi -g -Wall -D ARCH_VERSION=2 -D ARCH_RELEASE=6 -D ARCH_PATCH=0 -D ARCH_VERSION_TXT=\"2.6.0\" -I/mnt/disk1/tmp/jad/ca_test/base-3.14.7/include -I/mnt/disk1/tmp/jad/ca_test/base-3.14.7/include/os/Linux -I/usr/local/xerces-c-src2_4_0/include -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include ../FUX.cpp
make[2]: *** No rule to make target `../../../../lib/linux-x86//librecIoc.a', needed by `libTools.a'. Stop.
make[2]: Leaving directory `/mnt/disk1/tmp/jad/ca_test/extensions/src/ChannelArchiver/Tools/O.linux-x86'
make[1]: *** [install.linux-x86] Error 2
make[1]: Leaving directory `/mnt/disk1/tmp/jad/ca_test/extensions/src/ChannelArchiver/Tools'
make: *** [Tools.install] Error 2
It is looking for librecIoc.a in the wrong place? (extensions/lib/linux-x86 instead of base-3.14.7/lib/linux-x86)
Can someone please suggest how to fix this?
Regards and thanks,
John Dobbins
Lab for Elementary Particle Physics
Cornell University
Ithaca, NY
Re: Channel Archiver/ Extension Build Question Kay-Uwe Kasemir
Prev: Re: Running softIoc's in the background Brian McAllister
Next: help Xu HuiJuan
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Channel Archiver/ Extension Build Question Kay-Uwe Kasemir
