Dear Ms. Xu,
There is a free OPC Server Toolkit available, maybe it could help You to
explore the secrets of OPC server programming :-)
http://www.ipi.ac.ru/lab43/lopc-en.html
To tie an OPC-server to an EPICS-IOC would mean to give other non EPICS
control systems (as Labview and others that have an OPC interface,
mentioned by Mr Liyu) the chance to access EPICS process variables.
Since we use EPICS as control system up to now we had no need for that,
so nothing happend with us in this way.
What we have done here (the Germans mentioned by Mr Liyu) is the other
way, to tie an OPC-client to an EPICS-IOC to get process variables from
the hardware (PLCs) via their OPC-server into our EPICS control system.
For get into the OPC-server stuff, the lightOPC should be a good point
to start, but I have no experience with that. If You ever have an
running OPC-Server, it should not be a problem to use our EPICS device
support for the OPC-client and replace the IO-functions for the
OPC-client with Your new ones that point to Your OPC server.
Good luck
Bernhard Kuner
- OPC WITH EPICS Xu HuiJuan
RE: OPC WITH EPICS Liyu, Andrei
<2005>
2025
2026
Re: OPC WITH EPICS / OPC-Server for EPICS Matthias Clausen
<2005>
2025
2026
