1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: CAMAC-based stepper motor controllers
To: <[email protected]>, <[email protected]>
Date: Wed, 23 Nov 2005 21:31:03 -0500
	For what it is worth, I checked into the use of the Hytec
model #2404 at BNL's Accelerator Test facility. This facility
does *not* use EPICS. It uses Vista's Vsystem. Here are excerpted
comments from the user (I can post the entire reply if there is
interest):
> We don't have formal Vsystem support from Hytec for the 2404s, I just
wrote
> a library of functions and added it to our control system.  The 2404
is a pretty
> simple module with 4 channels per single CAMAC slot.
> We have a number of critical motors running
> with 2404s without problems and plan to introduce some more.
> Note that the ramp-up and ramp-down times are fixed at
> several discrete settings and are not continuously adjustable like the
E-500.
> My guess is that you would have no big problems integrating 2404s into
> an EPICS-based system.  From what I understand, Hytec is familiar with
> EPICS and does support it in many instances.
	I also have an electronic copy of the user manual. Although
I am sure Hytec can supply this to any interested parties, along
with price quotes.
Hope this helps. Let me know if I can supply any more info...
-- Larry
Prev: RE: EDM on Windows + Hummingbird? Liyu, Andrei
Next: virtual circuit disconnect Xu HuiJuan
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: CAMAC-based stepper motor controllers Brad Cumbia
Next: EPICS base compiling using Visual C++ 2005 Express guobao shen
