1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Using subArray
To: Carl Lionberger <[email protected]>
Cc: Michael Abbott <[email protected]>, [email protected]
Date: Mon, 28 Nov 2005 21:01:16 +0000 (GMT)
On Mon, 28 Nov 2005, Carl Lionberger wrote:
The thought was that the subarray record would be purely a soft record, and any hardware device support would be for waveform records that the subarray would read from. The MALM code makes sense in this context because the API for the dbaccess (as Noburu alluded to) always starts at element 0 of the source record. Therefore it is impossible to index an element larger than the buffer space you have.
You might consider writing a device support suite which supports a waveform record of the length you want and a couple of ao or longout records which control the index and length of the reference into the hardware..
Sure, I did think of that, and if the subArray gives me trouble then I'll revert back to that option. I still think the subArray might be smoother, despite the slight impedance mismatch on the interfaces. Have to confess before I opened the box I thought that's what the subArray was for!
It's true that to work in the way I'm thinking the subArray really needs to know *two* pieces of information in place of MALM: its own maximum length, and the maximum index into the stored array.
Using subArray Michael Abbott
Re: Using subArray Carl Lionberger
Prev: Re: Using subArray Carl Lionberger
Next: ASYN command string with null character Bruins, Stefan
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Using subArray Noboru Yamamoto
