1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ASYN command string with null character
To: "Bruins, Stefan" <[email protected]>
Cc: "'[email protected]'" <[email protected]>, Eric Norum <[email protected]>
Date: Tue, 29 Nov 2005 08:16:56 -0600
Bruins, Stefan wrote:
I presume this change has to be made in the "devSupportGpib.c" file of the
asyn driver in the function "writeIt"? Will a make of the ASYN module be
sufficient or must I run the makeSupport command a second time (this may be
a stupid question but I'm pretty new to EPICS/ASYN etc...)
No devSupportGpib.c does not need to be changed.
What you need to do is implement GPIBCVTIO. The devGpib documentation states:
GPIBCVTIO
Supports record types:
   ai, ao, bi, bo, event, longin.longout, mbbi, mbbo, mbbiDirect,
   mmboDirect, stringin, stringout, waveform.
   All I/O is done by the |convert| routine, which must be defined.
   |convert| is called by a callback routine and thus can make an
   arbitrary number of calls to low level drivers. It is passed the
   address of |gpibDpvt| which contains the information needed to call
   the low level drivers: |asynCommon, asynOctet, and asynGpib.| Note
   that | asynGpib| may not be present, i.e. |pasynGpib| is null.
   |gpibDpvt| also contains a field |pupvt| which can be used by the
   convert routine. Is is initialized to null. The macro |gpibCmdGet|
   can be used to get the address of |gpibCmd| which contains other
   usefull information.
Your convert routine can start something like:
static int myConvert(struct gpibDpvt *pgpibDpvt, int P1, int P2, char **P3)
 asynUser *pasynUser = pgpibDpvt->pasynUser;
 gpibCmd *pgpibCmd = gpibCmdGet(pgpibDpvt);
 asynOctet *pasynOctet = pgpibDpvt->pasynOctet;
 void *asynOctetPvt = pgpibDpvt->asynOctetPvt;
 asynStatus status;
Look in devSupportGpib.h for the definitions of gpibCmd, which contains the info in the gpibCmd in your source code.
I think Eric Norum has an example of how to implement GPIBCVTIO.
Marty Kraimer
RE: ASYN command string with null character Bruins, Stefan
Prev: RE: ASYN command string with null character Bruins, Stefan
Next: Re: ASYN command string with null character Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
