One thing I did not made clear in the previous email: the idea is that the
device has to respond to the message.
My first idea was to use the GBIBREAD operation for that, but this type has
only got a conversion routine for the reply. I had taken a look to the
GPIBCVTIO type, but this is not a query->response construction.
Is the only possibility to handle this creating a seperate "write" parameter
table to create the request without waiting for the response and using a
dummy "read" parameter table which is not sending any request but only waits
for the reply. Or is there a more "elegant solution".
-----Oorspronkelijk bericht-----
Van: Eric Norum [mailto:[email protected]]
Verzonden: dinsdag 29 november 2005 15:22
Aan: Bruins, Stefan
CC: 'Marty Kraimer'; '[email protected]'
Onderwerp: Re: ASYN command string with null character
If you're using the devGpib ASYN support you can create such messages merely
by providing a custom 'convert' routine. The tutorial at
http://www.aps.anl.gov/epics/modules/soft/asyn/R4-3/HowToDoSerial/tutorial.h
tml
shows how to do this. If your convert routine returns a non-zero value the
devSupportGpib.c code will use that value as the length of the message to
send.
On Nov 29, 2005, at 7:47 AM, Bruins, Stefan wrote:
I presume this change has to be made in the "devSupportGpib.c" file of the
asyn driver in the function "writeIt"? Will a make of the ASYN module be
sufficient or must I run the makeSupport command a second time (this may be
a stupid question but I'm pretty new to EPICS/ASYN etc...)
Van: Marty Kraimer [mailto:[email protected]]
Verzonden: dinsdag 29 november 2005 14:27
Aan: '[email protected]'
For the building of device support through the ASYN driver I have to sent a
message with a null character inside. The problem is that the driver
terminates the string at this null character according to the C++ standard.
My question is, how am I able to overcome this problem?
Stefan Bruins
You have to call pasynOctet->writeRaw instead of pasynOctet->write.
Marty Kraimer
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
- Re: ASYN command string with null character Eric Norum
FW: ASYN command string with null character Bruins, Stefan
<2005>
2025
2026
<2005>
2025
2026
