1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS R3.14.8 Release
Cc: EPICS tech-talk <[email protected]>
Date: Fri, 02 Dec 2005 09:40:16 +0900
Thank you very much for all contributed to 3.14.8.
Andrew Johnson wrote:
The new release of EPICS, Version 3.14.8 is now available for download from the EPICS website at APS. It contains many bug fixes, and the ability to make hardware address changes at run-time (provided the device support has been extended to support this).
This may solve the problem which Michael has, i.e. waveform
record with dynamic address to scan HUGE array of data on VME (or any kind of) device.[Ref."Using subArray" on tach-talk, Nov. 27]
Still, it would be easiler if we can use a subarray record(or similar) for this purpose.
Additional host and target support is provided for more Win32 build tools (mingw), and on Posix systems we have included code to make use of thread priority scheduling although this is not enabled by default.
Please be sure to read the RELEASE_NOTES.html file that comes with the distribution, as there are some configuration file changes that sites will need to be aware of.
Many thanks to the core developers for their hard work to achieve this release.
- Andrew
Noboru
EPICS R3.14.8 Release Andrew Johnson
Prev: PAS 9883/GEN Device Support? Ned Arnold
Next: [Fwd: Beam Line Scientist position at APS] Pete Jemian
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: EPICS R3.14.8 Release Andrew Johnson
Next: PAS 9883/GEN Device Support? Ned Arnold
