1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Mantis 232
To: "'Ernest L. Williams Jr.'" <[email protected]>
Cc: "'EPICS tech-talk'" <[email protected]>
Date: Thu, 8 Dec 2005 14:25:03 -0700
> What was the problem with R3.14.8?
Mantis 232:
A non-preemptive mode client that does not idle
in ca_pend_event and relies instead on ca_poll
or ca_pend_event with a very short delay may not
reconnect. The problem wasnt easily reproduced
on Windows or Solaris but may occur more frequently
on Linux.
The vulnerability in the source code appears to
also be in releases before R3.14.8, but may have been
influenced by thread scheduling timing differences
to occur more often in R3.14.8.
Sorry about any inconvenience this may have caused.
Jeff
> -----Original Message-----
> From: Ernest L. Williams Jr. [mailto:[email protected]]
> Sent: Thursday, December 08, 2005 2:04 PM
> To: Ned Arnold
> Cc: Liyu, Andrei; EPICS tech-talk
> Subject: Re: ca_host_name function in CA
> On Thu, 2005-12-08 at 14:50 -0600, Ned Arnold wrote:
> > Liyu, Andrei wrote:
> > > Hi,
> > > 	ca_host_name() function returns IOC name that have PV.
> > > 	This function is used in probe and gives IOC name and port
> > > number. So it isOk.
> > > 	When I use it in Windows, Epics 3.14.7, VC2003 I get local
> > > (client or OPI) PC name.
> > > 	Any idea?
> > > Thanks, Andrei.
> > This feature is broken in R3.14.7 (even on other platforms). Upgrading
> > to R3.14.9 (which will be out soon) will fix your problem.
> > By the way, you may have noticed I recommended R3.14.9.  We recently
> > found a problem with R3.14.8 and will be generating a new release
> shortly.
> This is also fixed in R3.14.8
> Mantis 181 - ca_host_name() now returns the host name of the client, not
> the host:port of the server
> > More later ...
> >    Ned
Re: ca_host_name function in CA Ernest L. Williams Jr.
Prev: Re: ca_host_name function in CA Ernest L. Williams Jr.
Next: order of DTYP and INP/OUT fields in db-Files and vdct Thomas Birke
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: ca_host_name function in CA Jeff Hill
