Marty Kraimer wrote:
Thomas Birke wrote:
we just found the "feature" again, that in record-sections of
db-files, the DTYP field has to be set before the INP or OUT field
(at least for INST_IO), it took us an hour or two to track this down.
I didn't search for that in the AppDevGuide and other docs, since I'm
afraid (and definitely hope), I'll find that documented, since I
found tha last reference to that "feature" on tech-talk back in '99.
It was undocumented back then...
Section 6.12 of the latest 3.14 Application Developers Guide contains
a subsection 6.12.2 which is titled "definitions" look for
DBF_INLINK, DBF_OUTLINK
In the NOTES it states that DTYP must be defined before the associated
INP or OUT field.
I looked and this note appears in the earliest 3.14 version of the
appDevGuide.
So at least, it's documented and I may even have read it, but it must
have slipped my mind... ;-)
I still suggest to change vdct to behave according to that.
Thomas
______________________________________________________________________
/homas.Birke @ bessy.de
BESSY Tel: +49 30 6392 4934
Albert Einstein StraÃe 15 Fax: +49 30 6392 4859
12489 Berlin
Germany
- order of DTYP and INP/OUT fields in db-Files and vdct Thomas Birke
- Re: order of DTYP and INP/OUT fields in db-Files and vdct Marty Kraimer
Re: order of DTYP and INP/OUT fields in db-Files and vdct Michael Abbott
<2005>
2025
2026
<2005>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
