I'm installing JCA1 on Linux to support existing Java applications.
The binary distribution of libjca.so is 124870 in size and works. If
I compile it from sources, it comes out with a size of 19330 and
doesn't work. Since I need to make a small change to the source, I
need to be able to build libjca.so from sources. Does anyone know
what switches are used to compile the binary distribution's library?
John Faucett
Los Alamos National Laboratory
- Variable scan rate Emmanuel Mayssat
- Re: Building JCA1 Janet Anderson
<2006>
2025
2026
<2006>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
