You can at least get information about external ca connections using the
"dbcar" routine.
Ernest
-----Original Message-----
Sent: Tue 1/10/2006 5:22 PM
To: Zhou, Jingchen
Cc: [email protected]
Subject: Re: How to check an external PV from IOC shell
Zhou, Jingchen wrote:
> Is there any simple way to check status of an external PV from IOC shell?
> For example, I am at a IOC shell
> epics>
> Is there any IOC shell command (or some way) that allow me do things like "dbpr external_PV" or "caget external_PV"?
> Thanks,
> Jingchen
I am not aware of any IOC based tools that support this *directly*. It
would be a useful utility if you chose to develop it.
However, there is always the hack!
If you have a spare record in your IOC (e.g. a soft AI record) you could ...
dbpf "softAI.INP", "externalPV"
dptr "softAI"
The STAT field will reflect if the external PV was found, the .VAL will
reflect its value.
Ned
- How to check an external PV from IOC shell Zhou, Jingchen
- Re: How to check an external PV from IOC shell Ned Arnold
RE: Timestamp record? UPTIME Emmanuel Mayssat
<2006>
2025
2026
RE: Timestamp record? UPTIME Steven Banks
<2006>
2025
2026
