Andrew wrote:
> Yes it is allowed, but you should be aware of the
> implications of this:
> If the semaphore blocks, then none of the other epicsTimers
> that use the same epicsTimerQueue will be executed until the
semaphore is released
> and the callback/notify routine returns. It is not advisable for a
> timer on the system shared timer queue to block for any signficant
> period of time in its callback/notify routine. The use of
> printf() and similar functions is fine though because it should not
block for any
> significant period of time.
I don't think I agree with the statement that printf() should not block
for any significant period of time.
On vxWorks printf() does block, and since the I/O is often going to a
9600 baud console port, it can be very slow. In fact if the user types
^S to pause the output the task will hang until ^Q is typed.
Here's a little test program that measures how many clock ticks are
required to use printf() to print 100 output lines:
corvette> more printf_test.c
#include <tickLib.h>
#include <stdio.h>
void printf_test()
int i;
long int start;
start = tickGet();
for (i=0; i<100; i++) printf("This is line %d\n", i);
printf("Total ticks=%ld\n", tickGet()-start);
Here's the output under normal circumstances:
ioc13lab> printf_test
This is line 0
This is line 1
This is line 2
This is line 3
This is line 96
This is line 97
This is line 98
This is line 99
Total ticks=72
value = 15 = 0xf
So it took 72 clock ticks, or over 1 second.
If I press ^S for a while during the output, the task hangs while that
is going on, and I got 546 clock ticks while I waited about 10 seconds.
So I don't think it's a good idea to call printf in a callback routine.
epicsPrintf() is much better, since it just puts output in a buffer, and
does not wait for the actual I/O to complete.
- RE: About: timeout handler of epicsTimer Jun-ichi Odagiri
Re: vxStats Benjamin Franksen
<2006>
2025
2026
<2006>
2025
2026
