1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Driver for Hytec 8601 IP Motor Controller?
To: "'Doug Murray'" <[email protected]>
Cc: "'TechTalk EPICS'" <[email protected]>
Date: Thu, 19 Jan 2006 08:59:25 -0000
Title: Message
Hi Doug,
There isn't an official Hytec 8601 Driver that supports the Motor Record.
The reason is that the Motor Record is in a slight state of flux, as Diamond / Argonne are re-working on it, Diamond is producing a template which we hope to test soon.
All the low levels of the driver exist and there is a simple version that allows analogue output records to control the motors.
Brian Kramper [[email protected]] at Fermi National Accelerator Laboratory has produced his own driver for the 8601, but I don't think its EPICS.
Darrell Nineham
Hytec Electronics Ltd.
Tel: +44 (0) 118 975 7770
Fax: +44 (0) 118 975 7566
Web: www.hytec-electronics.co.uk
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error, please notify the sender immediately. The views expressed in the message are those of the individual author and may not necessarily represent the views of Hytec Electronics Ltd.
-----Original Message-----
Sent: 18 January 2006 23:50
To: TechTalk EPICS
Subject: Driver for Hytec 8601 IP Motor Controller?
Does anybody have a driver for the Hytec 8601 IP Stepper Controller?
-doug
Doug Murray
LCLS Controls Group
Stanford Linear Accelerator Center
Driver for Hytec 8601 IP Motor Controller? Doug Murray
Prev: Driver for Hytec 8601 IP Motor Controller? Doug Murray
Next: Cost effective solution for monitoring a large number of temperatures Josh Stein
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
