1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: ASYN Question
To: [email protected]
Date: Fri, 20 Jan 2006 19:26:20 -0500
Dear All,
I have a serial device for which I am trying to implement Device Support
using ASYN. This is an EOS-901 from Eye on Science, a VAC ION Pump
controller.
There is one parameter, the Soft_Current_Trip_Level that requires the
following procedure:
1) Send: "UHV99S" (constant string)
2) Read: "Enter Alarm Limit\r"
(the unit will now wait until a new value is sent as follows)
3) Send: "0.000001\r" (value dependent string)
4) Read: "new limit=1.00e-06\r"
I can write a GPIBCVTIO routine that will accomplish all four
steps. Am I correct in assuming that no other gpibCmd for this device will process while my gpibCmd with the GPIBCVTIO routine is executing? i.e. the four steps cannot be interrupted by a request from some other periodically scanned record associated with this device?
John Dobbins
Laboratory for Elementary Particle Physics
Cornell University
Ithaca, NY
Prev: RE: Cost effective solution for monitoring a large number of temperatures Elder Matias
Next: RE: ASYN Question Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: synApps workshop part 2 - 20-23 February Rees, NP (Nick)
