1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: use of genSub record
To: [email protected]
Cc: [email protected], "'[email protected]'" <[email protected]>
Date: Fri, 27 Jan 2006 16:10:58 +0000 (GMT)
Hi Stefan,
On Fri, 27 Jan 2006, Tim Mooney wrote:
> Do you have any examples to work from?  If not, I could send you an example
> of the genSub record doing some simple array stuff.  I have only one example
> of a waveform record writing to hardware, and it's probably not a good example
> for your application, because the hardware is complicated and obtuse.
Along the lines of what Tim said, when you download the genSub record,
you will find a simple example database and code showing how to pass
arrays between two genSub records.
Hope this helps!
Cheers,
Andy
Observatory Sciences Limited    Email: [email protected]
William James House             Tel: 44 - (0)1223 - 508259
Cowley Road                     Fax: 44 - (0)1223 - 508258
Cambridge, CB4 0WX, UK          http://www.observatorysciences.co.uk
Re: use of SUB record Tim Mooney
Prev: EPICS Meeting Date is in Flux - please hold Dalesio, Leo `Bob`
Next: control systems and relational databases Claude Saunders
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: use of SUB record Tim Mooney
Next: RE: use of SUB record Bruins, Stefan
