1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: mallocMustSucceed( 0 ) non-portable
To: [email protected]
Date: Tue, 31 Jan 2006 23:51:02 +0100
On Tuesday 31 January 2006 21:42, Andrew Johnson wrote:
> Michael Abbott wrote:
> >>> Of course this means that callocMustSucceed and mallocMustSucceed
> >>> can return a NULL pointer, which they currently never do.....
> >> That's the dilemma. I thought about that but I believe requesting
> >> zero-sized memory and subsequent de-referencing the return value
> >> can be considered a programming error. Otherwise, I can't see how
> >> to avoid a memory leak.
> > Makes sense to me.  After all, what can you legally do with
> >     char * x = malloc(0);
> I understand that position, however I really don't like it.
> The ?allocMustSucceed() routines were always a bit of a hack to avoid
> having to check the return value from ?alloc.  They are only called
> in dbStaticLib and the IOC startup code in places where if you run
> out of memory there's no way you're going to be able to recover and
> still bring up the IOC, so the only thing you can do is bail out.
> They do that by printing an error message and suspending the task,
> thus ensuring that the caller never gets a chance to continue
> processing. The task suspend is to allow a developer to do a
> back-trace on the task that failed and thus find the rogue code, in
> the event that the problem is being caused by a bug rather than a
> lack of RAM.
One could argue that the same reasoning applies to all other kinds of
start-up code that gets executed more or less immediately after IOC
boot, e.g. in record and device supports init and init_record routines.
An out-of-memory situation here invariably means the IOC is overloaded
and obviously /cannot/ run as the developer planned.
Ben
RE: callocMustSucceed error handling model Jeff Hill
mallocMustSucceed( 0 ) non-portable Till Straumann
Re: mallocMustSucceed( 0 ) non-portable Michael Abbott
Re: mallocMustSucceed( 0 ) non-portable Andrew Johnson
Prev: Re: how to determine record type given pointer to a record Andrew Johnson
Next: RE: callocMustSucceed error handling model Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: mallocMustSucceed( 0 ) non-portable Andrew Johnson
