I have tried ArchiveViewer via Web start, and it works well.
Meanwhile, I have tried all the sort of things, and I was able to
compile simple Java program (with javac. I haven't tried with ant,
yet).
On 2/13/06, Sergei Chevtsov <[email protected]> wrote:
> Hi!
> I have never seen Java trying to allocate almost 1 GB of memory before.
> Are you able to run ArchiveViewer via Web start?
> http://ics-web1.sns.ornl.gov/archive/viewer/web_start/archiveviewer.jnlp
> If so, I would just recommend to build some other Java program. Please,
> be kind to report your results.
> Greetings,
> Sergei Chevtsov
> Jiro Fujita wrote:
> >Hello, my colleague Yury Gorbunov and I have been trying to build
> >EPICS ArchiveViewer 1.0.4 and getting an error message like this:
> >%> ant configure_jsp
> >Buildfile: build.xml
> >-create_build_dir:
> >build_all:
> > [javac] Compiling 842 source files to
> >/home/sysuser/epics/archive_viewer-1-0-4/build
> > [javac] jc1: out of memory allocating 1342179073 bytes after a
> >total of 548864 bytes
> >BUILD FAILED
> >file:/home/sysuser/epics/archive_viewer-1-0-4/build.xml:21: Compile
> >failed; see the compiler error output for details.
> >Total time: 1 second
> >We have spent several hours and cannot figure out what we are doing
> >wrong. It is on a Scientific Linux 3.0.5 with JDK 5.0 Update 6. We
> >have $CLASSPATH set to tools.jar and rt.jar provided by JDK 5.0, and
> >$JAVA_HOME set to /usr/java/jdk1.5.0_6.
> >Does anybody have suggestions??
- Re: building EPICS ArchiveViewer Jiro Fujita
- building EPICS ArchiveViewer Jiro Fujita
- Re: building EPICS ArchiveViewer Sergei Chevtsov
Re: labCA crashes with bad PV Eric Norum
ArchiveDataServer is ok Liu Shu
<2006>
2025
2026
<2006>
2025
2026
