1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: MVME3100 and EPICS (The successor to the MVME2100) a first look
To: EPICS tech-talk <[email protected]>
Cc: [email protected]
Date: Fri, 17 Feb 2006 12:47:29 -0500
We are looking for a low cost high performance PPC-based IOC to replace
the MVME2100 in the future. At some point we need to be ready for the
EOL of the MVME2100.
I have discovered the MVME3100 and currently have it running under
vxWorks 6.2 and EPICS R3.14.8.2.
ics-ioc-condor1>coreRelease
###  EPICS IOC CORE built on Feb 17 2006
###  EPICS R3.14.8.2-SNS1 $R3-14-8-2$ $2006/01/06 15:55:13$
value = 0 = 0x0
ics-ioc-condor1>
ics-ioc-condor1>version
VxWorks (for Motorola MVME3100-1152 - MPC8540) version 6.2.
Kernel: WIND version 2.8.
Made on Feb 17 2006, 08:28:38.
The MVME3100 is based on the E500 core.   Are there any other users
moving to vxWorks 6.2?
I know WindRiver is expensive; so who will do an mv3100 RTEMS port? :)
I have run a set of performance tests from Marty's test suite
(performApp):
Processing 213,000 records/sec.  That is twice the processing compared
to the MVME2100.
Of course, we will be running a lot more tests here and tweaking the BSP
as needed. For example, we have some applications that could use the
Signal Processing Engine (i.e. SPE support)
PS: WindRiver also offers a BSP for vxWorks 5.5.1
The following is an excerpt from the BSP documentation:
It consists of the
MPC8540 PowerQUICC III integrated processor with serial ATA, USB 2.0,
2eSST VMEbus interfaces, dual 64-bit/100MHz PMC sites, one flash bank
(with two boot blocks), dual 10/100/1000 Ethernet, one 10/100 Ethernet,
five serial ports, and a single SODIMM module.
The MVME3100 has its own transition board, but does not require one.
I have the following:
MVME3100-1152 667 MHz MPC8540 processor, 256MB DDR SDRAM, 64MB flash,
Gigabit Ethernet, SATA
And the most beautiful things is the list price of $1450 :)
Ernest L. Williams Jr.
SNS Control Systems Group
ORNL
Prev: segmentation fault in ca_task_initialize running in Linux Margaret Votava
Next: CA Port numbers now official Kay-Uwe Kasemir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: segmentation fault in ca_task_initialize running in Linux Margaret Votava
