Hello:
I have no good answer for this,
other than you might have to try to
figure out which CtrlInfo.h is actually getting included
when you compile LibIO/CtrlInfo.cpp,
since the errors indicate that the info
that should result from the #include "CtrlInfo.h"
a few lines above the errors that you get
should have taken care of the problem.
-Kay
On Feb 21, 2006, at 23:17 , liushu wrote:
Hello:
I have ever installed channelArchiver2.x with the default
installation(/usr/local) successfully.Now I want to install it
again in my
own directory(/home/liushu/epicsinstall/base3.14.7/extensions/),I Have
installed all the third party successfully,but when I compile
channelarhiver,I got errors like:
gmake[2]: Entering directory
`/home/liushu/epicsinstall/base3.14.7/extensions/src/
ChannelArchiver/LibIO/O.linux-x86'
/usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
-D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux
-D_REENTRANT -ansi -g -Wall
-D ARCH_VERSION=2 -D ARCH_RELEASE=6 -D ARCH_PATCH=0 -D
ARCH_VERSION_TXT=\"2.6.0\"
-I/home/liushu/epicsinstall/base3.14.7/base/include
-I/home/liushu/epicsinstall/base3.14.7/base/include/os/Linux
-I../../../../xerces-c-src2_4_0/include
-g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../
include
-I/home/liushu/epicsinstall/base3.14.7/base/include ../
CtrlInfo.cpp
../CtrlInfo.cpp:8: parse error before `::' token
../CtrlInfo.cpp:12: syntax error before `.' token
- error while compiling channelArchiver2.x liushu
Problem with e_flex in base Mark Rivers
<2006>
2025
2026
<2006>
2025
2026
