1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EZCA win32
To: <[email protected]>
Date: Thu, 23 Feb 2006 17:41:39 +0100
I need to develop a little application making some epics channel access under WindowsNT. I’m using Borland C++ compilator.
So, I used easy ca library for win32.
I’m just used some ezcaGet(…) and ezcaPut(…) functions in a very small code.
I linked with ca.dll.
Compilation and linking worked.
But, the ezcaGet(…) function  make the code very unstable and I don’t understand why.
In the following example, ezcaGat(..) works, but when I leave the main() procedure, the code systematically crashes!!!
int main (int argc, char *argv[])
  double d;
ezcaGet(“epic_data1 ",ezcaDouble,1,&d);
return 0;
Someone already meet this problem?
Thanks in advance
RE: EZCA win32 Jeff Hill
Prev: RE: GPIB swap 1014D with 1014 Waggoner, Bill
Next: Looking for Application Example John Dobbins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: It's ok now liushu
Next: RE: EZCA win32 Jeff Hill
