1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: IDL MCA and CA through firewalls??
To: "'Tim Mooney'" <[email protected]>, "'Antonino Miceli'" <[email protected]>
Cc: <[email protected]>
Date: Wed, 1 Mar 2006 10:18:14 -0700
A common configuration (at the APS and elsewhere) is to install a CA proxy
server
(a CA gateway) inside the firewall and then punch a hole in the firewall for
the server port
of the CA proxy server.
Jeff
> -----Original Message-----
> From: Tim Mooney [mailto:[email protected]]
> Sent: Wednesday, March 01, 2006 10:00 AM
> To: Antonino Miceli
> Cc: [email protected]
> Subject: Re: IDL MCA and CA through firewalls??
> Antonino Miceli wrote:
> > Hi,
> > I am trying to control (via channel access) a detector/IOC
> using the
> > IDL
> > MCA GUI. For reasons beyond my control, I cannot get this client to
> > install properly on a computer which lives on the same side of the
> > firewall as the detector lives.
> > However, I can run the IDL MCA client on a different subnet (and on
> > the
> > other side of the firewall). [For those at APS, I want to
> run the client
> > on oxygen (52 subnet), but my detector and it's IOC are
> behind a CAT
> > firewall (namely 248 subnet).]
> > So, it possible for an EPICS client to talk to EPICS server
> through a
> > firewall?
> Yes, but you have to get a network administrator to poke some
> holes in the firewall. By default, EPICS uses ports 5064 and
> 5065 for normal CA traffic.
> Tim Mooney ([email protected]) (630)252-5417
> Beamline Controls & Data Acquisition Group
> Advanced Photon Source, Argonne National Lab.
Re: IDL MCA and CA through firewalls?? Tim Mooney
Prev: Re: IDL MCA and CA through firewalls?? Tim Mooney
Next: vxWorks and ProFTPD Dale L. Brewe
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
