1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: archiveViewer JSP build
To: [email protected]
Date: Tue, 14 Mar 2006 13:11:03 -0600
I am building archiveViewer JSP on Scientific Linux Fermi LTS 3.0
and it failed with the following errors:
d0olk->ant configure_jsp
Buildfile: build.xml
-create_build_dir:
build_all:
    [javac] Compiling 842 source files to
/online/products/epics/v3_14_8_2/extensions/src/archive_viewer-1-0-4/build
    [javac]
/online/products/epics/v3_14_8_2/extensions/src/archive_viewer-1-0-4/src/org/jfree/chart/encoders/SunPNGEncoderAdapter.java:41: error: Class or interface `javax.imageio.ImageIO' not found in import.
    [javac]    import javax.imageio.ImageIO;
    [javac]           ^
    [javac]
/online/products/epics/v3_14_8_2/extensions/src/archive_viewer-1-0-4/src/org/jfree/chart/encoders/SunJPEGEncoderAdapter.java:44: error: Class or interface `com.sun.image.codec.jpeg.JPEGEncodeParam' not found in import.
    [javac]    import com.sun.image.codec.jpeg.JPEGEncodeParam;
    [javac]           ^
    [javac]
/online/products/epics/v3_14_8_2/extensions/src/archive_viewer-1-0-4/src/org/jfree/chart/encoders/SunJPEGEncoderAdapter.java:124: error: Type `JPEGImageEncoder' not found in the declaration of the local variable `encoder'.
    [javac]            JPEGImageEncoder encoder =
JPEGCodec.createJPEGEncoder(outputStream);
    [javac]            ^
    [javac]
/online/products/epics/v3_14_8_2/extensions/src/archive_viewer-1-0-4/src/org/jfree/chart/encoders/SunJPEGEncoderAdapter.java:125: error: Type `JPEGEncodeParam' not found in the declaration of the local variable `param'.
    [javac]            JPEGEncodeParam param =
encoder.getDefaultJPEGEncodeParam(bufferedImage);
    [javac]            ^
    [javac]
/online/products/epics/v3_14_8_2/extensions/src/archive_viewer-1-0-4/src/epics/archiveviewer/xal/view/tooltip/MultiLineToolTipUI.java:17: error: Class or interface `javax.swing.plaf.basic.BasicToolTipUI' not found in import.
    [javac]    import javax.swing.plaf.basic.BasicToolTipUI;
    [javac]           ^
    [javac]
/online/products/epics/v3_14_8_2/extensions/src/archive_viewer-1-0-4/src/epics/archiveviewer/xal/view/tooltip/MultiLineToolTipUI.java:25: error: Superclass `BasicToolTipUI' of class `epics.archiveviewer.xal.view.tooltip.MultiLineToolTipUI' not found.
    [javac]    public class MultiLineToolTipUI extends BasicToolTipUI
    [javac]                                            ^
    [javac]
/online/products/epics/v3_14_8_2/extensions/src/archive_viewer-1-0-4/src/epics/archiveviewer/xal/view/tooltip/MultiLineToolTipUI.java:0: internal compiler error: Segmentation fault
    [javac] Please submit a full bug report,
    [javac] with preprocessed source if appropriate.
    [javac] See <URL:http://bugzilla.redhat.com/bugzilla/> for
instructions.
BUILD FAILED
file:/online/products/epics/v3_14_8_2/extensions/src/archive_viewer-1-0-4/build.xml:21: Compile failed; see the compiler error output for details.
My settings are:
d0olk->echo $JAVA_HOME
/usr/java/j2sdk1.4.2_08
d0olk->echo $CATALINA_HOME/
/mnt/tomcat/jakarta-tomcat-3.2.4/
Can someone give any suggestions?
Vladimir
Re: archiveViewer JSP build Jiro Fujita
Prev: FW: Eclipse workshop, March 24th Chestnut, Ronald P.
Next: Re: archiveViewer JSP build Jiro Fujita
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
