1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: problem building 3.14.8.2 with win32-x86
To: [email protected]
Date: Fri, 17 Mar 2006 16:41:44 -0600
I'm having a bit of a problem building epics base 3.14.8.2 w/ the win32-x86 platform. The build progresses ok for awhile til I get output from gnumake (3.78.1 or 3.80) that ends w/
"Installing binary ../../../bin/win32-x86/Com.dll"
Usage:
         [ -m mode ] file ... directory
        -d             Create non-existing directories
        -m mode        Set the mode for the installed file (0755 by default)
        file           Name of file
        directory      Destination directory
Can't find file 'Com.dll*'
gnumake[3]: *** [../../../bin/win32-x86/Com.dll] Error 2
gnumake[3]: Leaving directory `D:/epics/base-3.14.8.2/src/libCom/O.win32-x86'
gnumake[2]: *** [install.win32-x86] Error 2
gnumake[2]: Leaving directory `D:/epics/base-3.14.8.2/src/libCom'
gnumake[1]: *** [libCom.install] Error 2
gnumake[1]: Leaving directory `D:/epics/base-3.14.8.2/src'
gnumake: *** [src.install] Error 2
I'm not sure I understand the reference to Com.dll* instead of Com.dll, but other than that I don't really know what might be wrong. Com.dll does exist in O.win32-x86. I'm using Visual C 6.0 and perl 5.6.1 from ActiveState.com or 5.8.8 from perl.com. The only changes I've made to the downloaded epics distribution is to uncomment the configure/os/CONFIG_SITE.win32-x86.win32-x86 file as suggested for vc 6 vs. .NET.
dale brewe
 Dale L. Brewe
 PNC-CAT/Argonne National Laboratory
ph: 630 252 0582 fax: 630 252 0580
Mail:
Bldg 435E sector 20
9700 S. Cass Ave.
Argonne, IL 60439
Re: problem building 3.14.8.2 with win32-x86 Ralph Lange
Prev: -Wtraditional ? Dirk Zimoch
Next: Re: -Wtraditional ? Janet Anderson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: -Wtraditional ? Janet Anderson
Next: Re: problem building 3.14.8.2 with win32-x86 Ralph Lange
