1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: antelope errors
To: <[email protected]>
Date: Wed, 22 Mar 2006 11:24:10 -1000
Aloha
This is more ignorance on my part. Do I need to track down the cause of the warnings in the input file or do I ignore these as there is a function call to remove_conflicts() (i.e. does that function fix things or delete the stuff that was found to be errant from the output?)? If the input file needs to be fixed is there a mechanism for enabling more error message so as to find the lines in question?
/usr/local/epics/r3.13.10/base/bin/solaris/antelope -t ../pvload.y
/usr/local/epics/r3.13.10/base/bin/solaris/antelope: 4 shift/reduce conflicts, 5
reduce/reduce conflicts.
mv y.tab.c pvload.c
Thanks for any help
AH
Re: antelope errors Ralph Lange
Prev: Re: Was this EPICS? Maren Purves
Next: RE: Was this EPICS? Kevin Tsubota
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Was this EPICS? Kevin Tsubota
Next: Re: antelope errors Ralph Lange
