1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: gateway enum writes
To: "Leicester, PJ \(Pete\)" <[email protected]>
Cc: Tim Mooney <[email protected]>, [email protected], Ken Evans <[email protected]>
Date: Wed, 29 Mar 2006 13:40:30 +0200
This is from the gateway code (gateVc.cc):
caStatus gateVcData::write(const casCtx& ctx, const gdd& dd, gateChan &/*chan*/)
int docallback=GATE_DOCALLBACK;
	switch(at) {
	case gddAppType_ackt:
	case gddAppType_acks:
		docallback = GATE_NOCALLBACK;
		// Fall through
	default:
			caStatus stat = pv->put(&dd, docallback);
			if(stat != S_casApp_success) return stat;
			if(docallback) {
				// Start a pending write
#if DEBUG_GDD
				fflush(stderr);
				printf("pending_write\n");
				fflush(stdout);
#endif
				pending_write = new gatePendingWrite(*this,ctx,dd);
				if(!pending_write) return S_casApp_noMemory;
				else return S_casApp_asyncCompletion;
			} else {
				return S_casApp_success;
It seems that ALL puts except alarm handler ackt and acks are done with callback. There is no direct flag to write() from the generic CA server which indicates writes with or without callback, as far as I can see. But the gateway should have look at the CA command in ctx, probably like this:
if (ctx.getMsg()->m_cmmd == CA_PROTO_WRITE_NOTIFY) {
  docallback == GATE_DOCALLBACK;
} else {
  docallback == GATE_NOCALLBACK;
Dirk
Leicester, PJ (Pete) wrote:
I can confirm that the problem appears isolated to the scaler record CNT
field and not enums in general.
It looks like Tim's ca_put_callback theory may be correct. Is there a
Gateway expert out there who can confirm this? How are writes done from
the Gateway. Does it always use ca_put_callback regardless of how the
put reached the gateway?
Thanks for everyones responses on this.
Pete Leicester
Diamond
-----Original Message-----
From: Tim Mooney [mailto:[email protected]] Sent: 28 March 2006 21:07
To: Leicester, PJ (Pete)
Cc: [email protected]
I am getting some strange behaviour when writing enumerations through
the Gateway (version 2.0.0.0 on 3.14.8.2 and RedHat Enterprise 4).
The problem first showed itself in edm when pressing a button on a edm
screen to send the value resulted in the following error:
   CA.Client.Exception...............................................
       Warning: "Virtual circuit unresponsive"
       Context: "diamrs0005l.diamond.ac.uk:6064"
       Source File: ../tcpiiu.cpp line 896
       Current Time: Tue Mar 28 2006 16:19:01.334736000
I did some further tests using caput with similar results:
   [pjl45@pc0005 pjl45]$ caput  -w15 GDA:scaler2.CNT Count
   Old : GDA:scaler2.CNT                Done
   Read operation timed out: PV data was not read.
   New : GDA:scaler2.CNT
       Warning: "Virtual circuit disconnect"
       Context: "op=0, channel=GDA:scaler2.CNT, type=DBR_TIME_STRING,
count=1, ctx="diamrs0005l.diamond.ac.uk:6064""
       Source File: ../getCopy.cpp line 82
       Current Time: Tue Mar 28 2006 17:04:24.488496000
Despite the above error message the write does actually reach the IOC.
However if I now try the change the value back as follows:
   [pjl45@pc0005 pjl45]$ caput  -w15 GDA:scaler2.CNT Done
   Old : GDA:scaler2.CNT                Count
       Current Time: Tue Mar 28 2006 17:22:36.167980000
I get an error again however this time the 'Done' value gets written to
the IOC exactly ONE MINUTE after I entered the caput command. This is long after the caput command has timed out so it appears the gateway
is
responsible for the delay?
Has anyone any idea what may be happening? Is there a 60 second timeout
in CA or the gateway which may give a clue as to what I am seeing?
(For the record this test was done with a very lightly loaded test
gateway serving only 20 or so PV's. Also using caput -w70 results in
the
same timeouts)
Do you get this kind of result with *all* enum fields that you write to
through the gateway, or only this one?  The scaler record's CNT field is
different from other enum's in that it starts an operation that may take
a long time to complete.  I don't know what the gateway is using to do
put's, but if it should happen to be ca_put_callback(), the gateway may
be waiting for a callback that will come only after the scaler has
finished counting.
-- Dr. Dirk Zimoch Swiss Light Source Paul Scherrer Institut Computing and Controls phone +41 56 310 5182 fax +41 56 310 4413
RE: gateway enum writes Jeff Hill
RE: gateway enum writes Leicester, PJ (Pete)
Prev: RE: gateway enum writes Leicester, PJ (Pete)
Next: RE: gateway enum writes Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
