1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: IOC shutdown signal(s)
To: [email protected]
Date: Mon, 03 Apr 2006 11:10:59 -0700
Hi All.
I am trying to set up a Linux host running a soft IOC, where there is a coordinated system of start-stop-restart commands available for maanaging the IOC as a system service. I would like to be able to issue a signal to the IOC to shut it down in a way that is at least as graceful as typing 'exit' at the IOC shell. Which, if any, signal does this? Is there any reason a new IOC could not be immediately started? The EPICS database may change between runs. In fact, this is the main reason for performing the restart.
Does anyone have a system of 'init.d' scripts that does this, and that they would be willing to share?
Rod Nussbaumer,
TRIUMF.
Re: IOC shutdown signal(s) Andrew Johnson
Prev: Re: Exiting IOC Andrew Johnson
Next: Re: IOC shutdown signal(s) Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: LabVIEW and ChannelAccess? Bill St.Arnaud
