1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: IOC shutdown signal(s)
To: Andrew Johnson <[email protected]>, Rod Nussbaumer <[email protected]>
Cc: [email protected]
Date: Mon, 03 Apr 2006 15:05:47 -0400
I'm hoping that Dave Thompson will respond with information about the
"procServ" we use here.
However, in addition to that, which lets you do a ^X on the console, or
exit(), (and I've used that to create a reboot record as suggested by
Andrew) - I've created scripts called lxRestart and lxRestartDev that
kill the processes and restart them under a user we've created for the
purpose of running soft IOCs.  My idea was that I did not want a process
needed by operations that couldn't be stopped or restarted by anybody
but me.
     Pam.
> -----Original Message-----
> From: Andrew Johnson [mailto:[email protected]]
> Sent: Monday, April 03, 2006 2:57 PM
> To: Rod Nussbaumer
> Subject: Re: IOC shutdown signal(s)
> Rod Nussbaumer wrote:
> > I am trying to set up a Linux host running a soft IOC, where there
is a
> > coordinated system of start-stop-restart commands available for
> > maanaging the IOC as a system service. I would like to be able to
issue
> > a signal to the IOC to shut it down in a way that is at least as
> > graceful as typing 'exit' at the IOC shell. Which, if any, signal
does
> > this? Is there any reason a new IOC could not be immediately
started?
> > The EPICS database may change between runs. In fact, this is the
main
> > reason for performing the restart.
> There is no signal (as in "kill -HUP" type of signal) to restart an
IOC.
>   You can create a subroutine record that calls exit() though and then
> use caput to do this (the softIoc binary that gets built by base
> includes such an exit subroutine already).  Alternatively you could
wrap
> your IOC binary with a script to do the restart, and just kill the ioc
> process directly.  We do something like this here at APS to ensure
that
> soft IOCs automatically restart themselves in the event of a crash,
> although we do have a restart limit counter to ensure they don't loop
> forever.
> - Andrew
> There is no S in exprexxo.
Prev: Re: IOC shutdown signal(s) Andrew Johnson
Next: RE: IOC shutdown signal(s) Al Honey
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
