1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ld error: Module contains undefined symbol(s) and may be unusable.
To: "Porter, Rodney R." <[email protected]>
Cc: [email protected]
Date: Tue, 04 Apr 2006 19:04:37 +0200
Hi Rodney,
you can do
nm<arch> *.o | grep _sysIntEnablePIC
on all object files which are included in your ANC library to find out which code uses that function. In you case, nm<arch> is probably nm68k and maybe you have to specify the complete path (same directory as your cross-compiler).
Most sys* functions are defined in the vxWorks BSP for your board. If they are missing, you have probably board-depending driver code which has been compiled for the wrong board. Are macro definitions missing or wrong?
Dirk
Porter, Rodney R. wrote:
I am running EPICS 3.14.8.2, vxWorks T2.2, synApps 5_1_1 with upgrades to motor 5-8 and asyn 4-4 to get streamDevice to work. For vxWorks-68040 I get the following load errors: ld < ANC.munch
undefined symbol: _sysIntEnablePIC
undefined symbol: _sysVectorIRQ0
value = 0 = 0x0
For vxWorks-ppc604_long I get the following load error: ld < ANC.munch
undefined symbol: sysIntEnablePIC (binding 1 type 0)
value = 0 = 0x0
I am assuming that these mean that some vxWorks system calls are not getting properly registered. Does anyone have a fix, or can anyone direct me to where the fix needs to be implemented (vxWorks, base, asyn . . .)?
Rodney Porter
Sr. Scientific Programmer
Data Aquisition & Detector Systems
Intense Pulsed Neutron Source
Argonne National Laboratory
9700 So. Cass Ave
Argonne, IL 60439 USA
Ph. (630) 252-7151
E-mail: [email protected] <mailto:[email protected]>
IPNS website: www.pns.anl.gov
-- Dr. Dirk Zimoch Swiss Light Source Paul Scherrer Institut Computing and Controls phone +41 56 310 5182 fax +41 56 310 4413
ld error: Module contains undefined symbol(s) and may be unusable. Porter, Rodney R.
Prev: ld error: Module contains undefined symbol(s) and may be unusable. Porter, Rodney R.
Next: Re: snc/seq enhancements ... local-variable access Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: EpicsHostArch.pl for Intel OS X machines? Eric Norum
