john sinclair wrote:
What's the correct file to edit to add a scan period. I have narrowed things
down to the following two:
...base/dbd/menuScan.dbd
...base/src/db/menuScan.dbd
The base/dbd directory is the install location where the file from
src/db gets installed to, so you don't want to edit anything inside
base/dbd or your changes will be lost when you next rebuild base.
Note however that you can also override the scan periods in an IOC
application by just providing your own modified copy of menuScan.dbd,
which will be found before the base one.
- Andrew
There is no S in exprexxo.
- Re: adding a scan period Emmanuel Mayssat
- adding a scan period john sinclair
<2006>
2025
2026
<2006>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
