1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Ethernet/IP Device Support and CompactLogix
To: John Dobbins <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>, John Barley <[email protected]>
Date: Wed, 05 Apr 2006 15:40:56 -0400
Hello:
On Apr 5, 2006, at 14:59 , John Dobbins wrote:
I have just used the EPICS Ethernet/IP device support to talk to an Allen Bradley CompactLogix (i.e. not ControlLogix) module.
So far I have written a bit to a DINT and read a PLC boolean. The only trouble encountered was an error/warning message on start-up:
    drvEtherIP: launch scan task for PLC 'compactlogixtest'
    EIP_startup: cannot determine target's identity
Well, unless there's some other error in the code that I don't see, this means:
The driver tried several "GetAttributeSingle" calls on the "Identity Object"
of the device, and that failed.
Specifically, it's trying to read the Vendor ID, Device Type, Revision, Serial # and Product Name,
which are all "Attributes" of that "Identity" object.
That was about the first thing I tried when implementing the driver.
I don't really care about the result except for diagnostics purposes,
so the driver will march on even if that fails
- and that seems to work out OK for your test.
But the thing is:
The ControlNET specification that I used when implementing the driver
(Release 2.0 Errata 2) makes no mistake that ".. the Identity Object shall
be present in all devices". And while some of its attributes are optional,
the Vendor ID ... Product Name are "Required" (Part 10a, p.2 & 3 of the specs).
This tells me that CompactLogix isn't fully spec compliant.
Might be OK, who cares about the serial number?
Might be problematic, because what else is different in the CompactLogix
interpretation of the specs?
Before I go any further with this test I wanted to ask if there is any chance of EPICS community support for CompactLogix - OR - should I send back this loaner, tell my colleagues that EPICS only supports ControlLogix, and turn my attention to other tasks?
This test came about because a colleague was interested in CompactLogix as it appeared to have lower capital costs. I gave them the spiel about EPICS device support only being demonstrated to work with ControlLogix but said if they could get a loaner I would give it a try.
Well, the beauty of the community is that several other people might be very interested in CompactLogix
and work with you on this.
As for me, I developed that driver because I originally needed it for my SNS-related work.
I still maintain it as far as bug fixes and adaptation to new EPICS releases are
concerned, and I would gladly attempt to incorporate any modifications that
allow its use with CompactLogix.
But since I'm not using CompactLogix, actually have not been using ControlLogix
in any of the subsystems assigned to me for years, it is very unlikely that I
can provide more active support for a CompactLogix adaptation.
-Kay
Re: Ethernet/IP Device Support and CompactLogix John Dobbins
Prev: Ethernet/IP Device Support and CompactLogix John Dobbins
Next: Re: AlarmHandler as a daemon or service Maren Purves
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Ethernet/IP Device Support and CompactLogix John Dobbins
