The following fix is needed for seq version 2-0-11 only.
Rename your RELEASE.<epics_host_arc> file to RELEASE.<epics_host_arc>.Common
or, if you prefer,
make the following changes to the configure/CONFIG file.
Index: CONFIG
RCS file: /usr/local/epicsmgr/cvsroot/epics/modules/soft/seq/configure/CONFIG,v
retrieving revision 1.11
diff -r1.11 CONFIG
3a4
> -include $(TOP)/configure/RELEASE.$(EPICS_HOST_ARCH)
17a19
> -include $(TOP)/configure/CONFIG_SITE.$(EPICS_HOST_ARCH)
Janet
Mark Rivers wrote:
Folks,
I am having problems building seq 2-0-11 for win32-x86.
In all other modules if I create a file called RELEASE.win32-x86 it uses
that file to define the locations of other modules, including base.
However, if I do this in the latest version of seq, it does not work. It
appears to be using RELEASE, not RELEASE.win32-x86.
When I do a "make clean uninstall install" at the top level of seq it
fails with the following:
cl /nologo /EHsc /GR -c -DPVCA /D_CRT_SECURE_NO_DEPRECATE
/D_CRT_NONSTDC_NO_DEPRECATE /D__STDC__=0 /Ox /GL /W3 /w44355 /MT
-DEPICS_DLL_NO -I. -I.. -I..\\..\\..\\include\\os\\WIN32
-I\\corvette\\usr\\local\\epics\\base-3.14.8.2\\include\\os\\WIN32
-I\\corvette\\usr\\local\\epics\\base-3.14.8.2\\include /Tp
..\\pvNew.cc
pvNew.cc j:\epics\devel\seq\2-0-11\src\pv\pv.h(16) : fatal error C1083:
Cannot open include file: 'shareLib.h': No such file or directory
make[3]: *** [pvNew.obj] Error 2
make[3]: Leaving directory
`/cygdrive/j/epics/devel/seq/2-0-11/src/pv/O.win32-x86'
make[2]: *** [install.win32-x86] Error 2
make[2]: Leaving directory `/cygdrive/j/epics/devel/seq/2-0-11/src/pv'
make[1]: *** [pv.install] Error 2
make[1]: Leaving directory `/cygdrive/j/epics/devel/seq/2-0-11/src'
make: *** [src.install] Error 2
The problem appears to be that it is using RELEASE to define EPICS_BASE,
rather than RELEASE.win32-x86.
RELEASE is:
# RELEASE - Location of external products
# You should do a "gnumake clean uninstall install" in the application
# top directory each time changes are made to this file
EPICS_BASE=/corvette/usr/local/epics/base-3.14.8.2
RELEASE.win32-x86 is:
EPICS_BASE=H:/epics/base-3.14.8.2
What needs to be fixed?
- Problems with files in seq-2-0-11/configure Mark Rivers
EPICS and phidgets... Kevin McIlhany
RE: Problems with files in seq-2-0-11/configure Laznovsky, Michael
<2006>
2025
2026
<2006>
2025
2026
