1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: DESC field containing embedded double-quotes?
To: Rod Nussbaumer <[email protected]>
Cc: [email protected]
Date: Mon, 24 Apr 2006 11:08:03 +0200
Staring at the code in .../src/dbStatic/dbLex.l and the other source files there, I would say that escaping a double quote is supported in a half-assed way:
\" doesn't end the string and hence is copied into the field, but no one ever takes out the backslash. Oops. Looks like a bug to me. I created Mantis entry 250.
Cheers,
Ralph
Rod Nussbaumer wrote:
EPICS Guruen:
I am generating EPICS .db files from a perl script, and would like to be able to generate records which have DESC fields containing the '"' 'double-quote' character. Is this possible? What is the syntax? I have tried editing an otherwise working database file, and have not been able to create one that passes the database loader. Have tried using combinations of multiple d-quotes and escaping them with various numbers of '\' 'backslash' characters.
I am using R3.14.8.2 on Scientific Linux 4.
Thanks.
Rod Nussbaumer,
Electronics Development Group,
TRIUMF
DESC field containing embedded double-quotes? Rod Nussbaumer
Prev: DESC field containing embedded double-quotes? Rod Nussbaumer
Next: Re: ???registrar(function_name) Liyu, Andrei
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
