On Apr 28, 2006, at 08:36 , mattei wrote: Hi all, I have built the Channel Archiver with base-3.14.8 under RHEL4. Everything seems to be working : I have checked the files with ArchiveDataClient.pl and ArchiveExport. Now I want to use the java ArchiveViewer. I can connect to the URL of my data server and choose some PV channels but when I ask for the "plot" I have the following error :
Please try the telnet check described in the "Data Server", "Testing, Debugging" section of the manual: telnet mywebserverhost 80 GET /archive/cgi/ArchiveDataServer.cgi HTTP/1.0<RETURN> <RETURN> You should see an error message about ``XML-RPC Fault: Expected HTTP method POST'', indicating that the data server was launched correctly and was looking for a proper XML-RPC request. ... Also check the file /tmp/archserver.log on your data server host. Per default, the archive data server will append to it whenever run. So it'll tell you if and how the data server is invoked in response to the java client requests. -Kay
| ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
