1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: asyn and Canberra TCA 2016
To: "Antonino Miceli" <[email protected]>, <[email protected]>
Date: Fri, 28 Apr 2006 14:56:05 -0500
Hi Nino,
I think the problem is simple.  Here is the syntax of the icbConfig
command:
#icbConfig(portName, module, ethernetAddress, icbAddress, moduleType)
#   portName to give to this asyn port
#   ethernetAddress - Ethernet address of module, low order 16 bits
#   icbAddress - rotary switch setting inside ICB module
#   moduleType
#      0 = ADC
#      1 = Amplifier
#      2 = HVPS
#      3 = TCA
#      4 = DSP
So your command should be
icbConfig("icbTca1", 0x98c, 1, 3)
not
icbConfig("icbTca1", 0x98c, 1, 1)
> -----Original Message-----
> From: Antonino Miceli [mailto:[email protected]]
> Sent: Friday, April 28, 2006 2:01 PM
> To: [email protected]
> Subject: asyn and Canberra TCA 2016
> Hi,
> I am running EPICS R3.14.7 on a MVME2700.
> I am configuring Canberra's AIM MCA modules. Having issues with
> the TCA module.
> icbConfig seems to be fine:
> value = 0 = 0x0
> dbLoadRecords("$(MCA)/mcaApp/Db/icb_tca.db",
> "P=dp3:,TCA=tca1,MCA=aim_adc1,PORT=icbTca1")
> value = 0 = 0x0
> But I get the following errors:
> 2006/04/28 11:11:17.728 drvIcbAsyn::drvUserCreate, unknown command=HI1
> dp3:tca1SCA1_HI devAsynFloat64::initCommon drvUserCreate
> command=LOW1
> dp3:tca1SCA1_LOW devAsynFloat64::initCommon drvUserCreate
> 2006/04/28 11:11:17.728 drvIcbAsyn::drvUserCreate, unknown command=HI2
> dp3:tca1SCA2_HI devAsynFloat64::initCommon drvUserCreate
> etc...
> Any hints on what this might be?
> Cheers,
> Nino
Prev: SNS reaches CD4 milestone!! Gurd, David P.
Next: Re: asyn and Canberra TCA 2016 Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: asyn and Canberra TCA 2016 Tim Mooney
Next: SNS reaches CD4 milestone!! Gurd, David P.
