Although other implementations may not be throwing exceptions, it
doesn't mean they are working as you expect. Casting double precision
numbers greater than LONG_MAX cannot work since there is no long
representation of them.
Running the following code using gcc on Linux shows that all in this
case the result of casting DBL_MAX to a long is LONG_MIN.
To write code that will always work, the value to be cast should be
compared to LONG_MAX first. To be really defensive, a case for negative
numbers, or those below LONG_MIN should also be added.
Malcolm
/* Test to show behaviour of casting of limits*/
#include "float.h"
#include "limits.h"
double dMax=DBL_MAX;
long lMax;
int main(int argc, char * argv[]){
lMax=(long)dMax;
printf("%e %d %d\n",dMax,lMax,LONG_MIN);
> -----Original Message-----
> From: Matt Rippa [mailto:[email protected]]
> Sent: 10 May 2006 02:49
> To: [email protected]
> Subject: MIPS epicsEventWaitWithTimeout(()
> Hi all,
> We're getting a floating point exception running iocInit() on
> a mips hkbaja47 with 3.14.8.2 exampleApp. Specifically this
> is the "timerQueue" task. Tracking this down it points to
> epicsEventWaitWithTimeout() inside
> base-3.14.8.2/src/libCom/osi/os/vxWorks/osdEvent.c
> The double timeOut passed in is DBL_MAX size (1.79769e+308)
> and used to calculate a semTake timeout. Basically, semTake
> and wait a very long time:
> int ticks = timeOut*sysClkRateGet();
> status = semTake((SEM_ID)id,ticks);
> The mips can't seem to handle the double to int conversion
> and ends up with an FPE and I think it's FPE_INVALID_OP.
> It can handle this when ticks is clipped to LONG_MAX*1.0.
> LONG_MAX*1.1 fails. We're wondering if there's any other
> gotchas if we do this for our mips targets?
> Of course it would be better if we could all run the same
> code. :-) Maybe we need to disable some FPE's for the mips?
> Does EPICS rely on disabling FPE's for all tasks?
> Many thanks,
> -Matt
> iocInit()
> Starting iocInit
> ### EPICS IOC CORE built on May 8 2006
> ### EPICS R3.14.8.2 $R3-14-8-2$ $2006/01/06 15:55:13$
> FPE Exception
> Exception Program Counter: 0x80d3c22c
> Status Register: 0x30006701
> Cause Register: 0x0000003c
> Task: 0x80f20870 "timerQueue"
> iocInit: All initialization complete
> -> tt 0x80ac70f0
> 80024434 vxTaskEntry +c : epicsThreadSleepQuantum
> (&epicsThreadCallEntryPoint, 80acf48c, 0, 0)
> 808cea18 epicsThreadSleepQuantum+78 :
> epicsThreadCallEntryPoint (eeeeeeee, eeeeeeee, eeeeeeee, eeeeeeee)
> 808c2f04 epicsThreadCallEntryPoint+a4 :
> timerQueueActive::run(void) (eeeeeeee, eeeeeeee, eeeeeeee, eeeeeeee)
> 808d4ee4 timerQueueActive::run(void)+40 :
> epicsEvent::wait(double) (800cfb5c, eeeeeeee, eeeeeeee, eeeeeeee)
> 808c8804 epicsEvent::wait(double)+28 :
> epicsEventWaitWithTimeout (eeeeeeee, 80acf494, 808c7a48, 80acfe10)
> -> ti 0x80f20870
> NAME ENTRY TID PRI STATUS PC
> SP ERRNO DELAY
> timerQueue 80d3c028 80f20870 129 SUSPEND 80d3c22c
> 80f205b8 0 0
> stack: base 0x80f20870 end 0x80f1d990 size 11840 high 1464
> margin 10376
> options: 0xc
> VX_DEALLOC_STACK VX_FP_TASK
> $0 = 0 at = ffffffff80d60000 v0 =
> 3c
> v1 = ffffffff80f20870 a0 = ffffffff80f28c90 a1 =
> 0
> a2 = 7fefffff a3 = ffffffffffffffff t0 =
> 30006701
> t1 = 30006700 t2 = 4 t3 =
> 0
> t4 = 0 t5 = 0 t6 =
> 0
> t7 = 0 s0 = ffffffff80f28c90 s1 =
> ffffffff80f20870
> s2 = ffffffff80f28e6c s3 = ffffffff80d34080 s4 =
> 0
> s5 = 0 s6 = 0 s7 =
> 0
> t8 = 0 t9 = 0 k0 =
> 8007823ceeeeeeee
> k1 = 0 gp = ffffffff80119dd8 sp =
> ffffffff80f205b8
> s8 = 0 ra = ffffffff80d3c21c
> sr = 30006701 pc = 80d3c22c
> fpcsr = 1000014
> fp0 = Inf fp2 = 2 fp4 = 6.31152e+08
> fp6 = 0
> fp8 = 0 fp10 = 0 fp12 = 0
> fp14 = 0
> fp16 = 0 fp18 = 0 fp20 = 1.79769e+308
> fp22 = 0
> fp24 = 0 fp26 = 0 fp28 = 0
> fp30 = 0
> FPE Exception
> Exception Program Counter: 0xvalue = 80d3c22c0
> Status Register: 0x = 0x30006701
> Cause Register: 0x00000003c
MIPS epicsEventWaitWithTimeout(() Matt Rippa
RE: MIPS epicsEventWaitWithTimeout(() Jeff Hill
<2006>
2025
2026
June EPICS Meeting reminder Andrew Johnson
<2006>
2025
2026
