After quite a long delay, we finally have a new release of irmisBase with many new features now in use here at APS. It is available as usual at http://www.aps.anl.gov/epics/irmis . See the README link (file also in root of tarball). What's New: Component-Type Viewer/Editor Component Viewer/Editor Cable Viewer/Editor User/Role Adminstration Several new crawlers: ADL (MEDM), ALH, IOC Save/Restore, SNL, SDDS There are now sql scripts for creating, altering, dropping, and pre-populating the database. These have been tested on a "from scratch" installation for both MySQL 4.x and Oracle 10. Most functionality of the applications has also been tested (informally) against MySQL and Oracle. The database pre-population scripts provide enough base component types to get started adding Buildings, Rooms, Racks, Chassis, Switch Gear, AC Panel, etc. As usual, the process of adapting the pv crawler to your site is typically a bit more work.
| ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
