1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: DirectLogic PLC ethernet driver?
To: Sue Witherspoon <[email protected]>
Cc: Geoff Savage <[email protected]>, [email protected]
Date: Wed, 31 May 2006 11:05:30 -0500
Hi Sue,
When I looked into the same issue with the DL405 with an H4-ECOM module, readout via ethernet, I discovered that you have your choice of protocols with which to communicate. Originally I wanted to use the directNetAsyn support from Andrew Johnson but discovered that this serial protocol does not match the DirectNet ethernet protocol. It is possible to used an ethernet to serial translator and use directNetAsyn. The H4-ECOM does not support the Modbus protocol for which there are EPICS drivers. So I elected to use the DirectNet HEI driver developed for Linux (from Host Engineering, hosteng.com) and create an ASYN driver that calls the HEI driver. Unfortunately this is not my highest priority project and I have just started reading back values.
Geoff
On May 31, 2006, at 10:04 AM, Sue Witherspoon wrote:
Has anyone developed a driver that would allow data to be received from a DirectLogic DL06 PLC via its Ethernet interface to an IOC?
Sue Witherspoon
Accelerator Control Software
Jefferson Lab
DirectLogic PLC ethernet driver? Sue Witherspoon
Prev: Re: DirectLogic PLC ethernet driver? Dirk Zimoch
Next: Beam in the Diamond Storage Ring Heron, M (Mark)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
